Harley hid versus motorcycle metal hid
Besides price, whats the difference between the two? and how come the moto metal version you have to use a switch to turn it on when the harley one turns on when you start the bike. considering howards light but don't like the idea of having to remember to turn headlight on.
You misunderstood. You turn the light off, not on.
1- If you wish the light to work just like the stock one than you leave the switch in the on position and it works exactly just like stock.
2- I personally like to start the motor (just like the old days when the government was not involved controling every part of your life) than turn my HID light on.
3- I also like the fact when your charging system goes out you can get some people to jump start the bike. A HD will start even if there is not enough power to turn on a LED.
I personally would rather drive my HD at 3 am without a headlight than push a HD at 3 am without a headlight.
It is a matter of when your charging system will go out and not if providing your ride enough. I can still remember breathing misquotes for hours in front of a closed strip club (just stopped there) until morning when my bike would not start. Your choice, push, stop, or ride. That is why.
Any modification with the exception of paste on Küryakyn chrome parts should be installed by someone with some kind of mechanical knowledge. Any plug and play HID kit should have a person with previous knowledge to be able to R&R a "Bat Wing" fairing or a "Roadking" nacelle and have it stay on. There are things that should be done to keep your parts functioning properly and the only way this is learned is by actually working on a bike.
The answer to your question comes down to how much experience and mechanical ability do you personally have? I have never seen a true plug and play HID unit from any other company as I can not buy them. I personally have to make or modify them to fit the application.
Every different bike such as a Road King compared to a Dyna compared to a Road Glide compared to a Street Glide compared to a Softail all have different wiring harnesses and other physical equipment such as the case between a Dyna and Softail compared to fairing bike. You need the correct ballast measurements.
I guess it comes down to experience on both sides.
When you can make the HID system not be visible on a Softail (ballast hidden between the frame & gas tank) and the only thing you see is a larger black headlight cable, that is a bit of experience. This is a CVO Springer done a few days ago.
This has been covered here several times, so have a look through past HID threads.
I have a Harley HID kit installed on my 1990 bike, which I adapted to fit. It is expensive and frankly not worth the cost! Beam shape is poor and main/high beam is next to useless, even with a 100watt high performance bulb.
HID usually only works on low beam and is very different technology to conventional bulbs. My recommendation, if you have a touring bike, is to buy a twin bulb reflector (some latest H-D models have them) and fit an aftermarket HID kit.
https://www.hdforums.com/forum/membe...rn-lights.html
The upper part is dip, with the HID bulb in it, the lower round part is high, with a conventional bulb. I don't reckon on using the high beam very often!
Yes! This is what it looks like:
kaotik78
05-17-2010 03:44 PM
