Air Pressure for E3's
Old 05-21-2009 | 08:49 PM
clap's Avatar
clap
Default Air Pressure for E3's
What air pressure are you guys running with the Elite 3 ,solo and two up , front and rear.
Old 05-21-2009 | 08:50 PM
wbogley's Avatar
wbogley
40 PSI all the time on the E3. You can run 35 in the front.
Old 05-21-2009 | 09:11 PM
VTwin-Goodies's Avatar
VTwin-Goodies
Sponsor
Running a higher pressure will make the tire last longer. When I ran dunlops, 40 and 40.
__________________
Old 05-21-2009 | 09:52 PM
iclick's Avatar
iclick
There is a limit to that principle. Dunlop says that if you go higher than the rated pressure (cold) the tire will protrude more at the center and thus will wear faster there. Since that's what wears the fastest on a touring bike the tire may be less durable if you inflate beyond the recommended pressure. I run 37F/40R cold, up to perhaps 38F when loaded, and am getting excellent wear from the rear. The front has only been on for 5K and shows no wear yet.
Old 05-21-2009 | 11:12 PM
dgretz's Avatar
dgretz
I run 36-38F and 40-42R Have 10K on both and still looking good
Old 05-22-2009 | 01:30 AM
ctmedic's Avatar
ctmedic
I,m running 38F and 40R. Almost 8K on them now and literally very little wear.
Old 05-22-2009 | 08:14 AM
XTrooper3936's Avatar
XTrooper3936
36 front and 40 rear, same as I used in the OEM Dunlops.
Old 05-22-2009 | 10:54 AM
Ribitt's Avatar
Ribitt
Cool
40 rear and 36-38 front, got 15K on last tire 5K more than the 402
Old 05-23-2009 | 06:00 PM
firefighter156's Avatar
firefighter156
Are the E'3 bias tires or radials??
Old 05-23-2009 | 08:55 PM
clap's Avatar
clap
They make them in both.But you want to run the bias on our Harleys. I think they make the radial for the Gold Wings.
Quick Reply: Air Pressure for E3's
