oil leak - AGAIN :(
oil leak - AGAIN :(
Last fall I had a primary oil leak that was fixed under warranty. Bike was in the shop a couple weeks.
Now less than 5000 miles later, there is a tranny oil leak.
Very obvious since I use that unique looking/smelling Redline ShockProof Heavy.
I get a couple drops after she sits warm for 10 minutes or so.
At least I can check the tranny fluid level easily
Any ideas on possible causes???
Riding season just started - ain't bringing it in until the leak gets real bad or the season is over.
I have heard of the old Harleys having constant oil leaks, but a 2005 with only 25,000 miles???
THANKS
Dave H.
THANKS
Dave H.
PEZ, can you comment please
Seriously though, I figure at say 2 drops a day, it'll be a month before I'm down even an ounce.
Actually measured it: 50 drops = 1 ounce.
Still at the top on the dipstick.
Thanks for the tips.
Dave H.
This is this is the correct way to repair the shifter shaft seal. The MoCo, to save a few pennies per bike, uses a single lip seal. That single lip seal has to seal the dirt out and the oil in. A tough job for a single lip seal in that dirty environment. Typically they last around 10k miles.
I too, had a shifter shaft seal leak, and replaced it with a Cometic "double lip" seal. James Gaskets also offers a double lip seal.
If under warranty, most H-D dealers will only replace it with the same POS the factory uses. Then you will be back again, only next time you pay for it because you're out of warranty. It's about an hour, maybe two at best to do the job. Take it to an indy and get it done right if the dealer won't use the aftermarket "double lip" seal.
