help arc amp problem
Old 05-22-2009, 06:20 PM
StreetGlideMedic's Avatar
StreetGlideMedic
StreetGlideMedic is offline
Wayne to the rescue! Now...that's customer service! He'l own and help with the problem and it's not even his! This should give ya'll some warm fuzzies about where to buy your product from!
Ride Safe, Mike
Old 05-22-2009, 06:50 PM
dubc's Avatar
dubc
dubc is offline
problem solved , I called arc for assistance, the problem was that I use cigarette light power for a remote. the tech said that isn't 100 percent for some reason and for me to use that unused orange wire on the head light wire harness , that fixed the problem. he said the lighter power was ify, some people have had that same problem as I
Old 05-22-2009, 10:50 PM
bigjimhp's Avatar
bigjimhp
bigjimhp is offline
Simple fix, My instructions said to use orange headlight wire, Glad you back rocking
Old 05-24-2009, 10:12 PM
Firecap501's Avatar
Firecap501
Firecap501 is offline
Former Sponsor
Art shoot me a pm and I will do you a new high level input just send the original back to me. If you are hooked up to the cig. plug let me know also, I will send you a new turn on wire to plug into the head light harness, this is where the ARC wiring harness is made to plug into.
Old 04-12-2010, 12:37 PM
HemiGlide69's Avatar
HemiGlide69
HemiGlide69 is offline
Hi Wayne,
Would like to get some info on the high level inputs and whatever else I can do to make this the best install I can. I have the Arc amp also.
Thanks
Old 04-12-2010, 09:18 PM
2D3K1H1B1HIM's Avatar
2D3K1H1B1HIM
2D3K1H1B1HIM is offline
Wayne ...Dave in Va....have had the same problem as mine wont turn on when you start the bike...works fine on acc or on start but when you fire the bike up no stereo.You said it might be HK radio not seeing 2ohm speakers....Sorry I never got back to you just been busy....also now I have a speaker that cuts in and out...not all the time...can you help me out....Thanks.........you....da. .......man
Edward Evans
Audio Systems
04-22-2019 03:11 PM
Jsnake
Audio Systems
07-22-2016 08:02 PM
decencyxdefied
Audio Systems
17
09-13-2015 05:19 AM
Mixter
10-18-2011 10:12 AM
Scottie83
04-08-2011 08:26 PM
Quick Reply: help arc amp problem
