Target AFR
Decel is when you take you hand off the throttle, for example when you pull in the clutch or to shift up or come to a stop. The 'Decel' area of a map typically needs to be rich or you will get Popping or Backfiring. Not sure how the PC is set up but in my TTS that would be the entire column at 20 MAP.
IMO the 13's is too rich for everyday cruising, but I don't have to contend with the heat like you baggers do... If you go in the 13's check you plugs after a few hundered miles to see if its to rich or not.
I'm using the original rich base map and applying leaner target AFR's. By doing this I can use a simple on-off switch to toggle between the richer base map and the leaner values created by the target AFR tables. If I get caught in traffic during summer I can switch to the richer base map (13.8:1) to cool things down. That way I can have the cooling when needed and good gas mileage most other times.
Do not apply any target AFR's to 0% TP (all RPM's) and 2-10% TP @ 1250 RPM. I use 0's in those cells, which makes the PCV use the values in the base map, as there is a history of problems setting target AFR's in those areas.
Hello.
I've recently installed Woods TW-6-6 cams and added the Auto Tune to my Fuel Moto PC-V (premapped)to my '09 SG. I ran the bike for about 300 mile's and then accepted all trims. I didn't change anything from Jamie's target numbers. The bike run's great accept I have a slight hesitation just off idle. The only time I really feel it is if I lug the bike from a dead stop. The bike seem's to stumble pretty bad. Other then that, bike run's great. Any idea how I can get rid of this hesitation just off idle. Thx. Rich
