Zumo Audio Question
Check this place out for the plug. Best 10 bucks you will ever spend. I was using a plug from phillips and this one is 2nd to none. Huge difference.
http://www.soundprofessionals.com/cg...item/SP-SPSC-7
If you do not have the audio cable for your bike get one here. You need the 24" and this has the 90 degree ends so it fits nice and tight to the radio and Zumo and they are gold plated. On sale for 10 bucks (Don't buy Radio Shack they don't work correctly).
I have my Zumo attached on the right side and a 2' cable was not long enough, so I'm using a 3' cable. Here is an auction for the same cable I have, which works fine.
