I plugged the O2 sensor locations without taking the headers off, had to use the O2 sensor tool just to get to them, the slot allows the wire connectors to turn with the socket. If you are taking the headers off anyway, you don't need the tool because you won't have a problem getting to them and can use a regular end wrench.
Since I had to dis-able my O2 sensors for the PCV, I can just throw some plugs in the sensor bungs huh? I should use some ant-seize on the threads right?
