'09 Grips (TBW)
Old 05-15-2009, 02:47 PM
nemick's Avatar
nemick
nemick is offline
Default '09 Grips (TBW)
I'm swapping from stock grips to some Performance Machine grips. Anything special I need to be aware of before doing this on TBW bike?
Old 05-15-2009, 03:53 PM
vzts4q's Avatar
vzts4q
vzts4q is offline
Not really! Actually easier to the than a cable type throttle. No adjusters to loosen and reset.
Just seperate the switch housings and pull the grip off. It has a internal spline that mates with the twist grip sensor.
Old 05-15-2009, 03:56 PM
BlackFLHR's Avatar
BlackFLHR
BlackFLHR is offline
If you have the same PM grips as I do, then you need to drill 2 dimples on the left bar where the set screws will rest. That will keep the grips nice and secure, since the left one doesn't actually go inside the switch housing but just butts up next to it.
Changing the grips on the TBW bikes is really REALLY simple.
Old 05-15-2009, 04:32 PM
nemick's Avatar
nemick
nemick is offline
Thanks for the advice guys. Just installed them and you're right, much easier than the cable type.
Old 05-15-2009, 04:48 PM
lp's Avatar
lp
lp is online now
Received 2,856 Likes on 1,602 Posts
I have three sets of these. One tip... take some heavy duty axle grease and put a little itty bitty smear on the inside of the right grip, just enough to keep it from dragging. Every set I have, after about a month of using them get all rough and drag and bind. You know feel grabby. It's because there is no teflon coating or anything in the grip - which sucks... Just a Dab of Grease has worked for me with no issues to the TBW.
lp
Old 05-15-2009, 05:26 PM
nemick's Avatar
nemick
nemick is offline
Great tip. I was surprised to see no form of wear ring or the like.
hogdiver96
03-27-2013 12:18 PM
pheur
08-10-2011 01:58 PM
jamala00
07-19-2011 05:22 PM
Conehead
08-19-2010 04:23 AM
alabama1
08-18-2008 07:55 AM
Quick Reply: '09 Grips (TBW)
