Fuel Mileage, 50 MPG?
#61
I have an 05 EGS, bone stock. I consistently get 48 – 50 MPG. Oddly enough I just finished installing fairing air deflectors, the between the forks air baffle, and the outside fork mounted air deflectors and my mileage went up to 56 MPG. Mind you I only have 1 tank so far, but I was surprised mileage went up at all, not down with the extra drag?? I should also add that I always travel secondary roads at about 50 to 60 miles per hour.
#63
#64
#65
I get 50 MPG have since the day I bought my Ultra...I have a buddy that has a classic we almost always take the same amount of gas each fill up....
#67
Made a trip from the coast to New Braunfels last week and checked mileage. 42.7 on the way up running 70 at 2500rpm. Slight tail wind
On the way home running 75 at 2800 rpm and a head wind, got the ole fuel light. Didn't bother filling up that night. The next morning 5.25 gallons or 32.4 mpg.
With tour pak
With tour pak
#68
I've found that riding like hell up steep hills and then coasting down tother-side in neutral with the motor shut down improves gas mileage. Truckers get a little pissed and their engine braking IS irritat'n but my wife and I have used this technique effectively .................. the other trick we use when faced with headwinds is to lay as flat as possible over the tank. Both techniques used together can get your gas mileage up to 55 MPG. Course depending on the day's riding condition it can lead to some tension later in the motel room/ campsite ............. but so far my needs remain satisfied in that respect.
