Spark Plugs?
Old 05-15-2009, 01:19 PM
gascap13's Avatar
gascap13
gascap13 is offline
Default Spark Plugs?
Which spark plugs do NOT have the little screw-on tops that the spark plug wire connects to? Have noticed that when my bike starts popping back through the carb, there is usually 1 or 2 loose spark plug tops.
Old 05-15-2009, 02:04 PM
cruise_carter's Avatar
cruise_carter
cruise_carter is offline
Put a dab of locktite on the screw on caps before installing the plug, no more issues.
Old 05-15-2009, 02:23 PM
gascap13's Avatar
gascap13
gascap13 is offline
Does that effect spark conductivity?
Old 05-15-2009, 03:14 PM
cruise_carter
Nope, just a small amount on the threads. I never had any issue. A very small amount of Locktite is all you need to lock it in place.
Old 05-15-2009, 03:26 PM
ngoti8tor's Avatar
ngoti8tor
ngoti8tor is offline
How many plugs do you have on your bike? Mine only has 2.
Old 05-15-2009, 05:43 PM
gascap13's Avatar
gascap13
gascap13 is offline
Alright.... 1 or both.
Old 05-15-2009, 08:42 PM
dawg's Avatar
dawg
dawg is offline
Received 3,222 Likes on 1,839 Posts
I didn't think the HD plugs had the screw-on tops do they? I know the Autolite ones that I use have them.
Old 05-15-2009, 09:04 PM
MNPGRider's Avatar
MNPGRider
MNPGRider is offline
Some have four, such as S/E Dual-Plug High-Compression Heads, and the Sportster Sport model came from the factory with dual plug heads.
Old 05-16-2009, 09:23 AM
OD_Cleaver's Avatar
OD_Cleaver
OD_Cleaver is offline
Road Dawg is right, the stock plugs do not have a screw on tip.
If you tighten the screw on tip with a pair of pliers before you install the plugs, you will end your problems as well. It is hard to over tighten if you are holding the plug with your bare hand. I think that the manufacturers of these plugs ship them loose, so that, the installer can quickly go either way.
Old 05-16-2009, 09:30 AM
Leftcoaster's Avatar
Leftcoaster
Leftcoaster is offline
+1 for the tighten them up with pliers - NO loctite (it can/does cause connectivity problems)
Quick Reply: Spark Plugs?
