Anyone have a SERT and not dyno'd their bike?
I suspect a lot of us have done just that. I'm over here in paradise with the nearest dyno being at least 1000 miles away. The beauty about the sert is you can load the closest map to your setup, hook up your computer and go for a short ride. When you get back, check out the data curves to see what to change next. About the only thing it won't do is measure the actual AFR.
sert
I bought my bike and had the dealer install the sert and stage 1 a/c and exhaust. They didn't dyno tune at that time. I rode it for 3 months and then took it in and had it dynoed. It had a lean bog off of the bottom that I wanted gone. The dyno run did the trick and I have been riding happy since.
I loaded map 100, and so far have just ramped up the CLB's to near max. Bike runs and starts great and have no complaints except it has a slight amount of decel pop.
I loaded the canned map that matched my components, took it for a ride and never looked back. Runs great. A dyno tune might get me more, but I know from the people I ride with, it wouldn't be enough to justify the expense. I did max out the clb table as instructed by someone who really knows his chit here on the forum.
Was going to ask a related question and I think it fits here. Bought a new SG last week and had SE AC, SERT, and Reinhart slipons installed. It runs fantastic, no popping, sputtering, etc. Not sure on heat or fule economy yet. So two questions:
1. Why would I want to spend the money on dyno tuning? This is pretty much addressed above.
2. The only thing they put in my bags was the SERT unit. No cables (which from other posts I can buy from dealer) and no disc. So if I want to have my indy change anything or dare to play with this myself, what do I need to do? I can see that I would need to buy a cable to hook computer up to bike. Do I need a disk, instructions, etc.? or am I chained to dealer if any adjustments are needed?
Thanks.
Thanks.
Thanks.
Thanks.
WouldBeHD
05-15-2007 11:36 PM
Rodman813
03-26-2007 05:15 AM
