Zumo Custom Routes
Zumo Custom Routes
I thought I would post this here since it seems that most of the Zumo threads are in the touring section.
I just ordered a Zumo 660 off of the Garmin website and it should arrive next week.
I'm planning on taking a 2200 mile trip to Colorado next month and would like to map out the whole trip beforehand.
My question is, if I create the route and get off of the main route to get gas, find a restaurant, ect, will the Zumo allow me to go back to the route that I have loaded, or will it recalculate and create a different route to my next destination?
It recalculates, but your original route is still in the unit. Simply go to "menu", under "Where to?" touch "Stop". That will stop the route & the recalculated route. Touch "Where to?" & re-select your custom route. Zumo will ask you if you want to start from the beginning. Answer "no", & it will pickup from where it is now. All this is from my 550, but I assume it'll be the same in the 660.
When I'm on a long trip, I like to preplan my routes for each day, and save them as Day 1, Day 2, etc. Even if you don't always know exactly where you'll spend the night, it's easier for me to manage. I can make changes to one day, without having to redo the entire route.
BTW, lots of great info on the Zumo Forums.
Late in the afternoon I found myself in the middle of "Nowhere Louisiana". Beautiful roads, but no motels to speak of. I pulled over & consulted the GPS for hotels/motels. The only ones I'd consider were a ways off at an intersection with an interstate hwy. I simply let the GPS pick the route to the intersection (didn't affect my original route), & wandered through some nice back roads to the motel cluster. Once there, I parked in one of the lots & called each of the motels since they were listed on the Zumo. Picked the one I wanted, made a reservation, rode across the highway, & checked in. Original route was still in the GPS & available for the next days ride if that was what I wanted. Regardless of the criticism, a good GPS is WAY better than a paper map!
NEW QUESTION. I have a ZUMO 660 and when I first got it I created some custom routes using the HD ride planner. Everything went ok; however, last week I made some changes to the existing routes and re-exported them to the Zumo. Next thing I know it is creating multiple versions of the route (i.e. Paris, Paris1, Paris2, etc), said it was out of memory and only had pieces of the route - not the whole thing. I deleted the routes in the Zumo, downloaded latest garmin communicator plug and created a brand new route. Same problem. I am at the point that I think I need to wipe the Zumo clean and re-pair my helmet commo & phone & re-load the maps I bought. Has anyone else had this problem and do you know of a fix? Thanks.
Guess what I'm sayin' is that if either you have updated the map set in the unit, or Harley has updated the map set in the Ride Planner, you're going to have to recreate all your routes. Wouldn't hurt to let the rest of us know how it works out..............
I created routes for my upcoming Alaska trip using MapSource on my PC and uploaded them to my Z660. When I fired it up, it asked if I wanted to convert the routes to the newer map. I'll set up a few local routes, let the 660 convert them, and then see how they compare to the actual roads here in the Dallas area.
Re: your sig file picture, ever fall asleep & roll off the low side?......
