If they are stock, they are sealed beams. You can get them at the dealer or aftermarket like J & P. You have options as far as what to put back in there. You may want to change them to a housing that has a replaceable (sp) bulb so you can put what you want in there. These are also availablat the dealer or aftermarket. There are also HID's and LED's that will fit in there.
I just want to put a new bulb in for now. I did not want to go to the dealer for one. By replacing the housing? Are you talking about the 05 and newer lamps? Thanks,vinnie
if they just take a bulb get the 880st it's sylvania just put these in the wife's spots and they light up the road you can get them at auto zone or walmart.
My '05 had smooth sealed beams. I changed them for the HD cut lens with changeable bulbs. I was just assuming the '03 was the same way stock. If you just need bubls, I believe you can use the 880's as mentioned above. They can be bought at any Autozone, Wallyworld, etc.
