You can lower it 1/2" with progressive 11.5" 440's. I did-I also lowered the front forks 1" with HD springs. It should be noted I have an RK Custom, not an SG, but the suspension setup is the same on both bikes. I don't know anything about the lowering kits.
You can get lower Progressive shocks for the rear and 06' HD profile lowering kit for the front. Hope ya like sparks! No way I would lower the rear any further unless ya like to pose more than ride.
Well I am only 5'6, and I could use another inch TRUST ME!!! But a 1/2 inch with a little stiffer air ride might work.
FOr the front I am going to need at least an inch in the front as I am installing a 21/18 combo set of wheels and have heard that you will need to lower the front an inch for the height difference.
