Notices
Rear pulley bolts
Old 05-05-2009, 10:17 AM
tgaetto's Avatar
tgaetto
tgaetto is offline
Default Rear pulley bolts
Can someone let me know what type stainless faster grade to use? I sheared off 2 of the chrome grade 8's? I think what happened is they loosened and then snap! Anyway I want to put it together again with piece of mind. I have alloy steel bolts but am afraid they'll be to brittle? I'd like to use stainless.....
Old 05-05-2009, 11:14 AM
strtglyd07's Avatar
strtglyd07
strtglyd07 is offline
Did they shear off agaist the swing arm ?
Old 05-05-2009, 12:46 PM
nvsteve's Avatar
nvsteve
nvsteve is online now
Yup they probably loosened. Be sure to use red locktite this time.
Old 05-05-2009, 12:47 PM
stro1965's Avatar
stro1965
stro1965 is offline
Just curious...do you have a chrome pulley cover? It seems like most of the time when I hear about this happening it's guys that have pulley covers. Just wondering.
Old 05-05-2009, 01:13 PM
oinker02's Avatar
oinker02
oinker02 is offline
Yep, it seems to happen once owners install chrome pulley covers on their belt pulley, or swap tires........Not because of the cover or the new tire, but because they didn't follow good engineering practice when they installed it.
First, buy only covers that come with new chrome plated high grade bolts, then use proper locktite and tightening sequence. Do not use stainless unless you can be certain they are proper grade.
Once installed and properly torqued, don't remove even to install new tire...If your tire shop ain't equiped with modern tire changer that can deal with pulley and rotor attached, then find another tire shop.....most bolts loosen or shear after tire change where pulley and rotor was removed to allow tire swap.
Old 05-05-2009, 02:19 PM
tgaetto's Avatar
tgaetto
tgaetto is offline
No chrome covers here, I am thinking that I did not use red? The wheels have just about 10K on them and I think in combination with the clutch, different gear and new cam which BTW is awesome (hq0034) I stressed the pulley? It appears that the pulley was moving around under load.
I think the fix is to go back to a stock pulley instead of the one that came with the wheels. I had to use a spacer to offset the belt for clearance. So its off to get a new pulley, bolts and tire. Metz 880 has held up well but as long as I am here it too will be changed.
The bolts did loosen and snap. The grade was A574 not 8....
Old 05-05-2009, 09:11 PM
gary_montague's Avatar
gary_montague
gary_montague is offline
Stay away from Stainless Bolts. The problem is not the bolts (grade 8) it's the installation. Some people think stainless bolts are a step up from grade 8. They are not. I am not entirely sure what grades they come in, but if you have a problem with them you will be sorry. They are a B**** to extract if damaged.
Old 05-05-2009, 10:07 PM
onthelo's Avatar
onthelo
onthelo is offline
I ran the stock bolts chromed with chrome washers, red loctite and man. torque specs. so far so good. Dont run the stainless I think there tinsel strenght might not be as strong. imo
Old 05-05-2009, 11:18 PM
OG1's Avatar
OG1
OG1 is offline
im no expert but i think grade 5 bolts have higher shear resistance than a grade 8. grade 8 is needed for tensile strength, but the pulley bolts are mostly on shear. also you might check that your bolts are not too long for your hub drill depth, seen it happen with some aftermarket wheels. if the bolt is coming tight and you can still spin the washer you might have this issue.
Old 05-06-2009, 07:25 AM
uweldit's Avatar
uweldit
uweldit is offline
I am a mechanical engineer, please heed my advice.
1. As most have already said, use the proper OEM bolts (go buy them from the dealer).
2. Loctite and torque per service manual.
Don't use any other bolt other than what is specified by Harley.
The OEM bolts are supposed to bend/shear under extreme circumstances before the whole drivetrain gets destroyed. It's called engineered failure.
Quick Reply: Rear pulley bolts
