oil coolers and oil pressure question
So, for those of you with oil coolers, I have a few questions.
Ok, so I've read the many posts on oil coolers and pretty much decided I want to add one to my Roadglide. (don't need to argue this point anymore) My question has to do with oil pressure.
With an oil cooler, should I expect the same oil pressure as without? I mean there is extra area that the oil is traveling to and from with an oil cooler. I'm assuming the oil pressure will not be affected during normal operating times.
But, what about at start up? Since the oil has a longer way to travel before it circulates, does it take longer for the oil to reach all of the critical components and get up to the normal oil pressure? Any problems with this? From the posts I reads thru, appears this is a non issue but just wanted to make sure I check before shelling out the money for the oil cooler.
Also, how much more oil will the crankcase hold with the Harley Oil Cooler (the one I'm planning on going with) Maybe a quart or less more oil?
I add the HD oil coolers and a fairing Oil temp gauge to all the performance baggers I build. There is no adverse effects on start-up or cold run whatsoever. The internal thermostat won't allow oil from the filter to the cooler through the filter adapter plate, until it opens around 190. You'll only be adding maybe a 1/4 qt more to the system.
Being from Ca. you have made the correct choice in deciding to add one.
The HD kit is a nice kit and easy to install.
Good luck
Kenny
Good luck
Kenny
I had an oil cooler on my '05 EGC. That bike took 4 quarts exactly on an oil change.
This new '09 RK holds exactly 3.5 quarts. Now I know one was a TC88 and this one is a TC 96 but I do think that extra half quart was for the oil cooler on my EGC. Someone correct me here if I'm wrong...
Oil pressure should not be effected by an oil cooler. Start-up shouldn't either.
Steve
yes sir
Good luck
Kenny
Good luck
Kenny
