What's Up With E-mail Notification?
Old 05-04-2009 | 09:04 PM
Intrepid175's Avatar
Intrepid175
My email provider is Comcast. I had similar problems until someone recommended registering for something like a gmail account and then having that system forward all emails to your primary account. That's what I did and have had no further problems.
I know it seems like a lot of BS to go through but it fixed the problem. Gmail offers their service free of change so this hasn't cost me anything so far.
FWIW!
Good luck,
Steve R.
Old 05-04-2009 | 09:29 PM
Taterdog's Avatar
Taterdog
Soos, set up a gmail account and your problems will be solved. Drove me crazy at first, but if you set it up and have it forwarded to your regular e-mail, it will work. Mine works great and has been for many months now.
Old 05-04-2009 | 11:04 PM
kpb46's Avatar
kpb46
You shouldn't have to go thru all that crap just to get notified. I use several different forums and this is the only one that does not work. The Honda one works (go figure)
Old 05-05-2009 | 05:59 AM
Taterdog's Avatar
Taterdog
You shouldn't, but you do, and it's apparently not going to change. Best thing to do is work the system, or live without notifications, or spend less time here. I gave up and finally decided to work the system, and it's worked fine since then.
Old 05-05-2009 | 06:25 AM
jharanin's Avatar
jharanin
I get the same stuff..comcast account.
Old 05-05-2009 | 06:36 AM
jharanin's Avatar
jharanin
I'm testing this gmail thing to see if I've set it up right...what a PIA.
Old 05-05-2009 | 05:02 PM
Intrepid175
Originally Posted by taterdog
you shouldn't, but you do, and it's apparently not going to change. Best thing to do is work the system, or live without notifications, or spend less time here. I gave up and finally decided to work the system, and it's worked fine since then.
+1
Old 05-06-2009 | 08:31 PM
soos's Avatar
soos
Hey Tater, I took your advice and opened up a Gmail account and selected forward email. It doesn't work. Screw it, I'm done with this.
Old 05-06-2009 | 08:37 PM
Taterdog's Avatar
Taterdog
Let me check my gmail account settings and I'll get back to you. Believe me, if it works for me it should work for you. I couldn't keep up without e-mail notifications. Be back in a minute.
Old 05-07-2009 | 06:18 AM
jharanin's Avatar
jharanin
Soos,
I did it and it's working...using Comcast. It took a little while before I got anything back.
Quick Reply: What's Up With E-mail Notification?
