Anti-dive technology and the dreaded low speed drop
Harley had used a primitive anti-dive set up in the early 90's. I had it on my 91 FXR-Conv. It was an air reservoir in the handlebars that fed into the front forks. It had a solenoid that closed off when you hit the brakes to keep the forks stiff. I guess it worked as intended, but as they said above, keep off that front brake in the parking lots.
I have always wondered why Harley-Davidson did not incorporate anti-dive technology in its front forks to help alleviate the propensity for us to drop our bikes when using the brakes during low speed turns. It is the weight transfer or "dip" in the front end that causes us to drop our scoots and wondered that the use of Anti-dive forks would stop or help cut down on this happening. Just a thought!
I personally don't think anti-dive tech is all that important. I've been riding dirtbikes with 12" of cushy suspension all my life (talk about dive), and as with anything else, as long as your going in a relatively straight line front braking is no problem. Also had a Ninja with anti-dive and didn't like it, it's not a natural feeling.
My Ultra dives to a degree but is still dead stable for what it is.
One inexpensive trick to help overcome some dive, is to replace your fork oil with a heavier weight oil. Did that to mine when I switched out to chrome front end, can't complain one bit about the front suspension now!
gjasr1960
General Topics/Tech Tips
10-14-2017 07:02 PM
rickoshay45
05-29-2008 04:04 PM
