Wild1 513s on 08 RG
Wild1 513s on 08 RG
Hi All,
I thought that I sould post some pics of the Wild 1 Chubby 513s on the RG.
It's been raining here for a week. I got bored so I decided to put these on. All wiring has been run inside of the handlebars (a must do with these).
The hardest part was making sure that I re-wired the Molex connectors correctly that I had to remove from the inner fairing so I could snake the wires through the handlbars. Since I did not have the HD special tool to remove the pins, I used a pin vise with a length of paper clip wire to make my own Molex pin removal tool.
I am really glad that I did this. The bars feel great and I can't wait to put some miles on the bike.
All stock wiring fit perfectly. All I had to do was relocate the brake line and clutch cable to the outside of the instrument nacelle.
If you take your time, you can definitely do this yourself. I took a couple of days becuse I was not in a hurry and I love working on my own bikes.
Road Glide® Handlebar - Satin Black '08-later FLTR models. No additional cables or lines required. Dimensions: Tip to Tip 31.50"; Base Width 10.50"; Pull Back 9.50"; Knurl 3.14"; Rise 6.75". 55862-09
Wild 1 WO 513
RIse 8.5" Width 35.0 Center 10" Pullback 11.5
Wild 1 WO 513
Wild 1 reccomends that if you go with the 10 inch rise then you will need a longer brake line. The 513s have a 8 1/2 inch rise.
My stock cables/wiring worked perfect. I did reroute the clutch and brake cables/lines outside of the instrument nacelle to make things loose enough for turning the handlebars.
There are many opinions on RG bars but I think the fit/finish of the Wild 1 Chubbys are top shelf. They are very comfortable.
