STARTER PROBLEMS!!!!!!!!!!! HELP
Hey i got a 98 RK... And when i press the starter button it sometimes engages and some times spins freely and some times spins freely and catches and and makes a god aweful noise......
And i'm fixin to go off on a ride this weekend and i don't want to get stranded!!!
ANY IDEAS ON WHAT IT COULD BE??????????
RE: STARTER PROBLEMS!!!!!!!!!!! HELP
Sounds like either a bad starter clutch or a broken tooth on the starter drive. My $$$ is on the starter clutch. My old RG would munch a couple starter clutches a year..... That's why I will NEVER buiild another bike with high compression.
Either the starter clutch or the drive gear can be replaced w/o replacing the starter. The starter clutch is ~$90 at a dealership. If you pull the primary cover and inspect the ring and pinion gears and do not see any missing teeth.... Get yourself the starter clutch, pull the starter and replace the starter clutch. It's essentially a sprag gear assembly that allows the pinion (or drive) gear to trun the engine over when it turns one direction, yet free spin when the engine starts and begins "pushing" the gear in the opposite direction - until the starter dis-engauges.
RoadRich2010
07-31-2012 09:52 PM
