Lowering kits for streetglides
Have an 09 street glide, looking to lower the rear, has anyone done this? and how? the 09 shocks are already shorter than the 08's
Have seen kits on ebay for like $40 to $50 are they any good? looks like relocating shocks? different angle??
Just looking for some info....
thanks
thanks
Never used the lowering kits you see all over, but if you want to keep the same shock travel there is a guy in Arizona that will cut your shocks down 1, 2 or even 3 inches and the ride stays pretty much the same. I had a set done a couple of years ago and they do everything he claims. Wasn't as cheap as a kit by anymeans tho. If you need the guys info PM me and I'll see if I can dig it up.
I put 11-1/2" Progressive 430 shocks on mine and lowered the front 1-1/2" with a race-tech gold valve kit. I hated every minute of it. The forks are terrible stock and not much better with the race-tech kit installed, but the shocks were a big improvement from the stock air shocks. I just bought a set of 12" Ohlins to get it back up, Dragging my floorboards every other turn, was starting to scare my lady. Now to fix/raise the forks... It sure looks cool all LOW, but it doesn't ride for $hit. The lower you go, the quicker it will bottom out, when riding two up. My tire was hitting my fender and it was like locking up the brakes. JMO
Thanks for any feedback.
I've got the three hole bracket style that kicks the shock back. I ran it in the second notch with 20lbs in the shocks. I' 220 lbs and the tire slapped the fender a little, when i rode two up it was so bad that i turned around, went home and moved it up. If i were to do it again I would'nt do this style again I would do shocks. My bud had another style on his 06 and it rubbed so bad that it shorted out the wiring harness that goes inside the fender, Do the shocks!
