What's up with these new Dunlop's?
Harley has changed to the D408 tires on the front due to cupping problems. The rotation has been reversed and tire renamed to correct the rotation label on the sidewall. Below is a copy of text from the notice. Do a search for Dunlop 408!
TT400 – January 29, 2009 – Front Tire Running Change 2009 Models
There will be a running change to the front tire on 2009 models. Dunlop D407F front
tires will be changing over to D408F tires during the first half of calendar year 2009. The
primary difference between the two constructions is the direction of the tread. This will
be executed as a running change for MY2009. The D408F tire will offer improved tire
wear for some customers over the D407F.
D407F D408F
Tires affected
D407s -- If I had them I would be running to the dealer demanding a replacement ASAP. These tires have uneven wear characteristics:
FROM CVO Harley----
Title: Re: 09 serg wobble
Post by: sblair on April 15, 2009, 10:31:35 PM
Started having it when I let off the throttle. Also noticed that my front tire was cupping. The new D407's are doing this. The trailing edge of the pattern is wearing much more than the leading edge. My tire whe inspected closely was almost bald at the trailing edge pattern while the leading edge was quite healthy. I check tire pressure every 2 weeks and go by the book. Well, appears there is an alert out and I got a warranty replacement with the new D408 tire. Wobble is gone!
Be pi$$ed! They should have tested this crap before using riders as QA testers.
FROM CVO Harley----
The tire is inside out!!!
That is amazing! I have never seen this before.I am subscribing to this thread to see what happens or happened.
Scratching head real hard on this one. Great post!
This is what happens when I dont read the entire thread..
On my 09 FLTR I have the D407F and it looks like the photo of the red bike. I have thus far no wear issues to speak of. Note that on Dawgs reply, HD says that "The D408F tire will offer improved tire wear for some customers over the D407F." That doesn't sound too serious to me. I'll monitor the wear more closely now though.
