Digital Dip Stick/Oil Temp.
This is for those that have the digital dip stick/temp. gauge. I know there a lot of people here that hate 'em, & probably with good cause. However, I have one, & while it hasen't been trouble free it's pretty handy.
I just finished takin' it apart for the second time. After a while the oil that gets pushed up in it will reach the window. You can still read the temp. & oil level, but it's a little dark. The first time I took it apart I simply cleaned it. This time it wasn't workin' at all so I cleaned it & replaced the battery. It's the same battery as the alarm fobs use (at least Harley is consistent).
All that's needed for repairs is a small phillips screwdriver & either the smallest torx you ever saw or a straight slot jewelers screwdriver. I use the latter. No water on the electronics, but soap & water will remove the oil from the cap once you have the electronics & display out.
They're a little more accurate than the fairing mounted gauge, & push button oil level is worth the effort. YMMV........
You will be perfectly OK without one. I personally want to keep tabs of engine oil temps.
