Headlight Trim Ring
Headlight Trim Ring
Recently installed an HD Dual Lamp Halogen Bulb and a headlight Visor Style Trim ring on my 09 SG. After securing it as much as possible, I find that it still wobbles somewhat if you try to move it with both hands from side to side. Don't want it to fly off while travelling......
Anyone else experienced this and if so, any ideas on eliminating this problem would be most appreciated.
I just replaced the chrome trim ring with a black one and have the same problem. I don't see the function of the spring clip at the top of the ring. When I pulled the original there was a pop when the clip let go. I've removed it since and it didn't seem to be clipped on anything. It hasn't come off after about 200 miles, but it does move back a forth if I use both hands. Hopefully someone else has the handle on this...it ain't rocket science.
If you're talking about this trim ring, then I feel your pain. It fits kinda big and when you go to tighten the screw on bottom, as it snugs up it leaves a big gap. I remember reading that people were putting weather stripping inside the ring to get a tighter fit around the original housing and that would eleminate the gap. I haven't gotten around to trying it yet....
Fatguy
