I wanna put my EZ-Pass inside my fairing.
RE: I wanna put my EZ-Pass inside my fairing.
Yes, I do. I tried installing it on the inside lid of my right saddlebag, but it did not work, and that was without having a passenger on whose leg would kinda block the signal if you follow me. I think a blocked signal would happen if I mounted it in the TP with a passenger on. I have a feeling that the EZ-Pass units are a low power, low signal unit.
The fairing has seven screws holding it on. Three across the bottom of the windshield, one on each side of the inner fairing, just below the hand grips, and the other two between the forks where the brake line splitter rests. You can wiggle it out from behind the passing lamps, and then unplug the headlight. There is plenty of room for a pass but I can't say the best spot for it.
