LED Blinkers with Security System
Old 04-25-2009 | 05:05 PM
maineultraclassic's Avatar
maineultraclassic
Default LED Blinkers with Security System
I just installed some led bulbs into my directionals, both front and rear. It's an equal load as it's the same bulbs all the way around. But for some reason my security system doesn't like them. When I hit the directional button, they blink normal for 3-4 blinks then they get very fast. And when I start the bike, the security key light is staying lit on the dash.
Any ideas?
Thanks,
Steve
Old 04-25-2009 | 05:31 PM
cruise_carter's Avatar
cruise_carter
I had led turn signals on my 02 RG, without an additional load equalizer nothing worked right.
Old 04-25-2009 | 05:37 PM
StreetGlideMedic's Avatar
StreetGlideMedic
THis is normal when you add LEDs on all four corners. I do suggest the addition of the badlands Illuminator load equalizer. It's not the cheapest one...but the easiest to install ,creates ZERO heat and I think the safest. Let me know if ya need help...I'll be happy to talk ya through if if you need!
Ride Safe, Mike
Old 04-25-2009 | 05:52 PM
CW4_131A's Avatar
CW4_131A
Load equalizers are required for LED's. The LED's don't pull the same amperage as standard bulbs. The effect is that your electrical system 'thinks' your light are not working. A load equalizer tricks your system into reading the correct amperage. Once you've installed an equalizer your faults will disappear.
Old 04-25-2009 | 09:09 PM
maineultraclassic
Badlands Generation III Load Equalizer plug-n-play module = $69.95 delivered
Looks like I'll be ordering one of these this week.
Steve
Old 04-25-2009 | 10:39 PM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
What kind of LED lights did you use?
Old 04-26-2009 | 01:15 AM
Potato_Potato's Avatar
Potato_Potato
The LEDs might have an equal load in all 4 corners but they are not equal to the load as incandescent bulbs that you replaced. The TSSM is looking for a very specific load and if it isn't there it's not happy — you need an equalizer.
Old 04-26-2009 | 01:19 AM
StreetGlideMedic
Good Deal on the Badlands...Let us know how it works out!
Mike
Old 08-03-2009 | 04:17 PM
hyfly1's Avatar
hyfly1
I added some LED accent lights, plugged in to the Maxi-fuse connector. Now the security system idiot light glows all the time. The lights are not designed to flash, so I'm wondering if i still need a load equalizer to make the security system happy? Would it make a difference if I plugged the accent lights into another connector?
Tee Bagger
01-10-2012 06:58 PM
upstate tim
07-11-2010 08:48 PM
hyfly1
08-10-2009 10:47 AM
glide05
03-02-2009 05:13 PM
cycle_j
07-27-2006 10:09 AM
