Rattle at Idle?
Old 04-25-2009 | 08:55 AM
Lightngsvt2's Avatar
Lightngsvt2
Default Rattle at Idle?
I've noticied something wierd on my 09 SG, when at a light depending on if I have the brakes held or not determines how much it vibrates. If Im sitting with no brakes or only the rear brake it is pretty smooth, but if I hold the front brake the vibrations increase quite a bit and I hear a metallic rattle that seem to come from the right side rear of the bike. Only happens when the front brake is help, any ideas?
Old 04-25-2009 | 09:29 AM
workformetoo's Avatar
workformetoo
Most of the time it's a muffler mounting bracket (on mine) making that noise.
Old 04-25-2009 | 09:56 AM
cruise_carter's Avatar
cruise_carter
check the mounting bolts on the rear caliper, if they are loose the caliper will rattle and its heavy enough to cause vibration. Holding your rear brake on keeps it from moving.
check asap to ensure it doesn't cause an unsafe condition and torque them to spec.
Old 04-25-2009 | 09:59 AM
1flhtk4me's Avatar
1flhtk4me
Mine did the same thing.
Old 04-25-2009 | 10:02 AM
georgemcghee's Avatar
georgemcghee
+1 same here
Old 04-25-2009 | 10:47 AM
jsimo7's Avatar
jsimo7
rear brake pedal rattle .. maybe?
Old 04-25-2009 | 12:02 PM
Gearhead3's Avatar
Gearhead3
I've noticed the vibration while holding the front brake, also. The only rattle I've found on mine (so far) is from the shift lever.
Old 04-25-2009 | 12:27 PM
fastbagger's Avatar
fastbagger
Same here on my '09 FLHX. It is coming from my left handgun housing. When I put my hand on it, it goes away. It is odd.
Old 04-25-2009 | 03:56 PM
Lightngsvt2
I checked and nothing I can see seems loose.
Old 04-26-2009 | 06:36 PM
Lightngsvt2
In case this can help someone in the future, I figured out the problem. the bolt holding the front bracket for the right side saddle bag had fallen out so the bracket was banging against the mounting surface.
avasquez097
08-14-2018 05:44 PM
raceme
09-20-2015 11:44 PM
cmonster
11-30-2010 10:23 PM
tt_ksu
03-21-2009 10:51 AM
tt_ksu
Wheels/Tires
03-20-2009 08:32 PM
Quick Reply: Rattle at Idle?
