I have a 2006 FLHTI. It has 15,000 miles on it.
Just replaced the rear tire and while being done the front motor mount was found cracked in half. I was noticing a lot of extra shaking at about 75 mph.
Is this common or just my bad luck?
Personally, I'd have the bike's alignment checked. The procedure is explained in the HD Service Manual for your bike. The procedure often results in noticeable realignment of the engine in the frame.
Breaking front motor mounts is not unheard of, but I don't have any data from which to characterize it as "common."
I have an 07 and I think mine is worn also. I thought there was a different one to use than the stock one, but I am not sure anyone remember this or am I dreaming. Thanks AL
There is a service bulletin out for the 06 motor mount. My 06 EGC let go in Kansas while on a road trip. The dealer there replaced it free of charge to me.
sbfd8, there used to be polurethane replacement mounts, surely still available, although not sure how well they'd work. i remember them in the older catalogs.
