??? For the audiophiles ???
Hi Gang,
I am currently in the selection stage for all of my audio updates.
I have a few questions concerning the equipment.
1. I am going to install a DVD with 7" screen, and have been looking at all of the specs & such for weeks. One thing that really sticks out is:
** On the less expensive units, the pre-amp volt output is usually 2 volts. On the more expensive units, the pre-amp volt output is 5 volts.**
How big of a difference is this in the end, if I am going to run an Alpine PDX 4.150 ??
2. I am going to go with either the Infinity Kappa Perfect 6 1/2's in the batwing & 5 1/4's in the Ultra rear spots, or the Boston Acoustics in both.
Any opinions ?? And ,..............what size wire should I use for speaker wire ??
3. Is there a big difference in the RCA cables that I run ??? Any suggestions on the best ones to buy ??
4. Do I need to install any switches/ relays, etc. , for safety of the system. ( Now I have an "empty" switch that was hooked up to the rear speakers.
5. I want to do this ONCE and have it be RIGHT the first time. Money is not really an object, if it results in a better end product.
Thanks in advance !!
Hey, you have specced some high end gear, should sound unreal.
The reason for higher head unit output voltage is to combat noise. The vehicle environment is an electrically noisy one.
Your amplifier is receives a low voltage from the head unit and increases it to a higher voltage (and current). This voltage is the music. The problem is, electrical noise may be present and that too will be amplified resulting in alternator whine, ignition noise, etc. If you turn the amplifier gains down, the electrical noise is amplified less, but so is the music. The higher voltage head units put out more so you can still get satisfactory volume with the power amp gains reduced thus the system sound to noise ratio is improved!
Wires are like oil, people beleive certian ones are better without any real evidence. In my experience you def can not hear any difference between $4 and $40 RCA leads.
Dont get carried away with speaker wire size either, your speakers will come with wires and they might look small but they are right...
Wires are like oil, people believe certain ones are better without any real evidence. In my experience you def can not hear any difference between $4 and $40 RCA leads.
Don't get carried away with speaker wire size either, your speakers will come with wires and they might look small but they are right...
glacier, i really suggest using a arc 4ch mini for now (not the alpine, which is what i have), pm firecap for specs and tell him i sent ya...
Hey there
The voltage out of the radio is important, however the voltage means little without the line impedance rating to go along with line voltage. The line impedance is more attractive the lower the number is. Think of the line voltage like the fuel line going to the motor. The bigger the fuel line is the more attractive it may appear, but without any pressure to carry that fuel, the larger line isnt so good to the overall bikes performance.....
Eclipse was the first company to make a big deal about line out voltage. Their early radios were 2.8 volts out at 200 ohms. 200 ohms is considered a low impedance (good). The lower the line impedance the better the sound. As the line impedance goes up, the less lower bass and higher treble can be reproduced. Some cheaper radios today boast 5v out but the actual line impedance is about 2000 ohms--the radio is really bad! When I was still with Rockford in Canada, they had a radio that was 5 volts out at 50 ohms and it kicked a$$! Today, since the average consumer doesnt know about the ohm rating, many companies claim a 5v out, but the line impedance is so high, the net sound is poorer than a 2 volt radio at 500 ohms.
Alpine should have the line out and line impedance somewhere on their site. I think they still care about this stuff. Even if you find a decent 5v deck with decent line impedance, you need to make sure you have an amp that can "take" that much signal going in. If you find the Alpine 5v radio has a good spec, I would most likely stick with one of their amps as well. If your going to mix and match amps and radios, I would stick to a good 2 volt deck with low line impedance--PEZ
Thanks so far for all the tips !! I will have to check the line impedance of some of the models I like.
Really like the Kenwood KVT-819DVD unit.
http://www.kenwoodusa.com/Car_Entert...ent/KVT-819DVD
A couple good explanations here but seriously, on a bike it really doesn't matter. Just stick with a decent brand of HU and you will be ok. That Kenwood is a decent HU but I perfer Alpine. One of the best combos I've had is an Alpine W200/H701 and I'm still using it in my truck. Seriously, you are thinking TOO much into this set-up when you start talking about pre-out voltage and RCAs. If you are really that serious about it, go with balanced lines like on (my favorite) Zapco amps! That takes care of any noise in the lines you could be worried about but wont hear riding down the road anyway (if you set-up everything properly).
I remember when Eclipse came out with the 8 volt units...I had to have one. I ended up going back to Alpine because of Alpine's usability.
Pez, I think you are talking about the infamous Denford (8250). It was a HU made by Denon rebadged as a Rockford.
Kenwood has 2 1/2 times more preamp voltage.
Kenwood has 3 EQ bands, Alpine 0
Kenwood has "security code" function, along with detachable face. ( thieves know that this unit is worthless without the passcode)
Kenwood has STANDARD auxiliary & USB inputs
Kenwood has USB memory cardslot
Kenwood warranty is 2 years, compared to Alpine 1 year
These things are ALL very important to me !!
If you are gonna spend the $$$ that I am, I would like the most BANG , and options for my buck.
