??? For the audiophiles ???
The top of the line Alpine , IVA D106, doesn't seem like it compares to the top of the line Kenwood, KVT-819DVD.
Kenwood has 2 1/2 times more preamp voltage.
Kenwood has 3 EQ bands, Alpine 0
Kenwood has "security code" function, along with detachable face. ( thieves know that this unit is worthless without the passcode)
Kenwood has STANDARD auxiliary & USB inputs
Kenwood has USB memory cardslot
Kenwood warranty is 2 years, compared to Alpine 1 year
These things are ALL very important to me !!
If you are gonna spend the $$$ that I am, I would like the most BANG , and options for my buck.
Also like I mentioned before, when you start looking at voltage of the pre-outs and RCAs it starts to be a moot point on a motorcycle install. One of the biggest, most important equations of an install is exactly that...the install. Sound deadening, imaging, time alignment, xover settings, active or passive, a capable electrical system and then more sound deadening, etc (not to mention a sub and enclosure). These are all factors that really do not matter in a motorcycle install. To me it just does not make sense to sweat the small stuff without concentrating on the install as a whole. Seeking out some of the other features (USB, security, etc.) of that HU, sure.
Something that is VERY important though...a big part of buying mobile audio is buy what sounds good to you, what makes you happy, what makes you feel good.
Hey there
The voltage out of the radio is important, however the voltage means little without the line impedance rating to go along with line voltage. The line impedance is more attractive the lower the number is. Think of the line voltage like the fuel line going to the motor. The bigger the fuel line is the more attractive it may appear, but without any pressure to carry that fuel, the larger line isnt so good to the overall bikes performance.....
Eclipse was the first company to make a big deal about line out voltage. Their early radios were 2.8 volts out at 200 ohms. 200 ohms is considered a low impedance (good). The lower the line impedance the better the sound. As the line impedance goes up, the less lower bass and higher treble can be reproduced. Some cheaper radios today boast 5v out but the actual line impedance is about 2000 ohms--the radio is really bad! When I was still with Rockford in Canada, they had a radio that was 5 volts out at 50 ohms and it kicked a$$! Today, since the average consumer doesnt know about the ohm rating, many companies claim a 5v out, but the line impedance is so high, the net sound is poorer than a 2 volt radio at 500 ohms.
Alpine should have the line out and line impedance somewhere on their site. I think they still care about this stuff. Even if you find a decent 5v deck with decent line impedance, you need to make sure you have an amp that can "take" that much signal going in. If you find the Alpine 5v radio has a good spec, I would most likely stick with one of their amps as well. If your going to mix and match amps and radios, I would stick to a good 2 volt deck with low line impedance--PEZ
also check out the JVC KD-AVX77, its what i am thinking about using, i got tired of the whole flip out and clarion... but i always change things up...
Do you have any experience with JVC's iPod interface?
anyhow, i got the jvc for an awesome deal... so i am going with that...
