Tool Roll Mistake
Old 04-20-2009, 06:33 PM
cdestuck's Avatar
cdestuck
cdestuck is offline
Veteran: Marine Corp
Nothing i can say that Tgaetto didn't say in one word.
  #32
Old 04-20-2009, 06:56 PM
HDJIM1158's Avatar
HDJIM1158
HDJIM1158 is offline
First let me say sorry for the damage....But dude...That is a lot of damage...what was in the bag and what type of hole or holes did you hit ??? I can not believe you didn't hear or feel anything until you got home. Be Safe JIM
  #33
Old 04-20-2009, 07:37 PM
Whiskers's Avatar
Whiskers
Whiskers is offline
How many miles do you have on your bike?
Reason I'm asking is I did the same thing and finally discovered that the oil in my forks needed changing. If your bike has 20,000 +/- miles you need to get it changed...may not have been the tool bags fault.
  #34
Old 04-20-2009, 07:45 PM
Maxcustody's Avatar
Maxcustody
Maxcustody is offline
That is one hell of a dent. Thanks for the heads up.
  #35
Old 04-20-2009, 08:32 PM
skratch's Avatar
skratch
skratch is offline
Received 4,357 Likes on 2,536 Posts
hd recommends fork oil change at 50k on 07 and newer. changed mine to se heavy at 25k. feels much better.
  #36
Old 04-20-2009, 09:10 PM
mefreer's Avatar
mefreer
mefreer is offline
Stage I
Default tool bag dent
I did the same thing on a new 1991 FLHS while driveing onto a ferry. It was the first big fork compression I had. Ended up getting a new factory painted fender. There was nothing wrong with the forks.
  #37
Old 04-20-2009, 09:17 PM
busch's Avatar
busch
busch is offline
Man that sucks better luck next time
  #38
Old 04-20-2009, 09:18 PM
santajim's Avatar
santajim
santajim is offline
As I said before all I had in the kit was that measley little MO CO tool kit from now on it will go in the saddlebag. The highway was California highway 80 over Donner Summit and it sucked rough as hell,Thought I was going to have put her in 4x4 to get over and I am sure that was part of the trouble. Update called HD dealer today and then called my local paint distributor loca can't match paint cause it's special hd paint 3 stage and HD wants $285 for a quart of the three parts of the paint stuff so I'll straighten the fender and put that small area into red primer for now. oh by the way only have 4500 miles on bike so don't think it's fork oil but thanks guys for the thought and responses. I guess I just wanted to let all you good HD folk to be careful and to VENT a little
SANTA
  #39
Old 04-20-2009, 09:29 PM
Lucky 13's Avatar
Lucky 13
Lucky 13 is offline
I've seen alot of damaged fenders from bags and even a radar detector but thats the worst I've seen. I feel for you. Even if you can fix it yourself, its a PITA.
  #40
Old 04-20-2009, 09:31 PM
Arizona's Avatar
Arizona
Arizona is offline
Originally Posted by leicafish
Thanks for being humble and supplying the heads up.
+1 Thanks for the heads-up as that could happen to any one of us. Though I have heard of guys mounting even a Gremlin bell in that area on some bikes and getting a dent.
Glad to hear you can fix it yourself at least - the rest of us would be shelling out the 100's!
Quick Reply: Tool Roll Mistake
