Erratic Oil Temp Guage Readings
Hey guys...
I've installed the oil temp gauge on my 07 streetglide in place of the worthless air temp gauge. The temp sending unit is mounted to the oil pan. I've noticed that at times the gauge is pegged. A quick tap with the finger and the gauge moves back to more what I expect the temp to be.
How do you go about trouble shooting this?
Is there a way to isolate what the bad part is without having to buy a whole new gauge?
I'm kinda of the belief the problem is with the gauge itself since tapping it with a finger "corrects" the problem.
Possibly a ground problem - get all that teflon tape off if there is any and see if that helps. Next try switching the power source to a different location. Mine was erratic and I found out it was getting interference from an aftermarket brake flashing unit. Dealer moved power source off of the brake circuit and it works fine now. I'd try easy stuff like this before actually swapping out the gauge or sending unit.
Hey guys...
IIRC pegging the gauge means a direct short in the sender circuit, as if you lose the ground or sender connection it will peg toward the zero end. On the HD gauges the small circuit board is at the rear of the gauge and exposed, so if your wrench slips while installing and it damages the traces you may have an inoperable gauge. Since it's sporadic I doubt if that's the cause, but like you I would put my money on a short inside the gauge.
I appreciate the input!
Don't bother checking, as it doesn't matter one way or the other. Just make sure none of it gets loose and starts floating around in the oil flow. Napa does carry this adapter, #3220 x 6 x 2 (1/8F-3/8M).
