V&H TRue Duals
Old 04-19-2009 | 07:04 AM
JayStronghawk's Avatar
JayStronghawk
Thumbs up V&H TRue Duals
Installed Vance and Hines True Duals and can say if money well spent .. I kept my Python Mufflers they are Made by V&H anyway and the Sound is Great seems to run a little cooler with a little better throttle response as well ..
Old 04-19-2009 | 07:25 AM
Phurion's Avatar
Phurion
Noticed the much cooler right side immediately after I had mine installed a few weeks ago. All related to the removal of that danged down-pipe on the right side. Was about to buy some RJ's before the TD's, but don't really need 'em anymore (other than they look really cool =). Also noticed a HUGE sound improvement (true/full balanced stereo sound from each pipe behind me vs "almost stereo" of the stock headpipes).
Getting the bike dyno'd this month, so may see a minior improvement in performance. Even if I don't though, it was definitely a mod that I won't regret. The two benefits I listed above were worth the minor expense.
BTW...diggin' where you're going with the contrasting black accents against the silver motor.
Old 04-19-2009 | 07:29 AM
JayStronghawk
Thanks, was a Chrome Freak for a while but figured Black would Look better against the Auminum...
Old 04-20-2009 | 08:10 PM
Jukebox's Avatar
Jukebox
So Jay,did you do anything to the air cleaner or is it still stock?
Old 04-20-2009 | 08:14 PM
old skool1983's Avatar
old skool1983
lookin good bud, i dig all the black on her
Old 04-21-2009 | 05:02 PM
cfmii11's Avatar
cfmii11
True duals are the cats a$$ as far as I'm concerned.
Old 04-21-2009 | 05:32 PM
briggs07's Avatar
briggs07
Hows bottom end with the true duals? A friend of mine has rinehart true duals with the screamin eagle race tuner and air cleaner, had the dealer tune it and his bike is slow as hell. Has no low end power, we all blow him away going up the mountains. Id like to do a true dual setup, but after seeing how slow his bike is i really dont want to lose power. Also he gets horrible gas mileage. We will both fill up at the same time and hes on empty while im at just under a half tank. Both bikes are 08 dresssers.
Old 04-21-2009 | 06:23 PM
RenoGlide's Avatar
RenoGlide
Put a set of V&H Duals on mine last week because of a cracked Y pipe. I kept the Supertrapp SEs on there & it sounds nice. Definately less heat on the right thigh.
I have dyno tuned several mild built bikes with Rineharts & each were kinda weak in the lower RPMs. A few more experienced tuners told me it was because of the larger pipe ID and that HDs need back pressure for torque. Im sure its not the case for all with Rineharts, but it was with the ones I worked on.
Old 04-21-2009 | 06:35 PM
Maxcustody's Avatar
Maxcustody
Very nice.
Old 05-21-2009 | 04:23 PM
woods's Avatar
woods
Hey Jim,
I am running Supertrapp SE mufflers and just bought a pair of V&H Duals. They are in the mail right now.
Just wondering if you noticed any performance change with going from stock head pipes to the duals?
Quick Reply: V&H TRue Duals
