My pipes are too loud. Recommend something else.
Old 04-18-2009, 04:00 PM
OldArmy's Avatar
OldArmy
OldArmy is offline
Elegant solution--never seen it before. I may give it a try. Looks like you went about an inch plus into the pipe upstream of the muffler. And no challenges with backpressure? I'm wondering if it will freak out my ECM when closed. I probably wouldn't keep it closed all the time. Thanks again
Originally Posted by xxxflhrci
OldArmy,
They really simple....Just 1" washers welded on a 1/4" bolt stem. You could use larger washers for more "baffle" if you wanted to. I cut a slot in the bottom of the stem so I could tell which way they were turned in the pipe and turn them with a screwdriver to adjust them.
Old 04-18-2009, 05:35 PM
Scooter68's Avatar
Scooter68
Scooter68 is offline
Originally Posted by Anthony8858
I have a 2005 RKC with V&H true duals and Oval Slipons. The bike sounds awesome, but I;m getting tired of them. I was thinking about changing the slip ons to something more low-level deep rumble.
I want a pipe louder and deeper then the original factory pipes, but not as loud as the V&H Ovals.
Any suggestions?
I run a set of SE slip ons, they are pretty easy on the ears and and nice and kinda quite at cruising speeds. I'd like to change to a set of Monster ovals or or oval slip ons to match my dresser duals. If you really want to change let me know maybe we can work out a deal to swap plus $ from me.
Old 04-18-2009, 07:11 PM
Pastor John's Avatar
Pastor John
Pastor John is offline
Rodeo will argue against it, but I wonder if the Monster Ovals would be a good compromise for you? Not as loud or raspy as the Oval Slip-Ons, but still more sound than stock.
The SE Street Performance Mufflers (64985) are excellent as well - a little quieter than the Monster Ovals, but still more sound than stock.
BTW Rodeo - I suspected we were kindred spirits all along - one of my early bikes was a 305 Scrambler as well! What great memories that picture brings!
Old 04-18-2009, 08:12 PM
stratplexi's Avatar
stratplexi
stratplexi is offline
Received 1,084 Likes on 562 Posts
Supertrapp SE are the best bang for the buck. These slip ons are only 3db louder than stock and in a test in American Iron they outperformed nearly every other set of slip ons. I think there was one set that had like .1 more peak HP but had less torque. These slip ons perform and give you that deep tone that is just a little more than stock.
Old 04-18-2009, 09:20 PM
iclick's Avatar
iclick
iclick is offline
Any suggestions?
Dyno-tuned Jackpot from Fuel Moto.
Old 04-19-2009, 03:21 AM
xxxflhrci's Avatar
xxxflhrci
xxxflhrci is offline
[QUOTE=OldArmy;4881781]Elegant solution--never seen it before. I may give it a try. Looks like you went about an inch plus into the pipe upstream of the muffler. And no challenges with backpressure? QUOTE]
I actually did it to give me some more back pressure.
Old 04-19-2009, 05:33 AM
masterblaster's Avatar
masterblaster
masterblaster is offline
I went with the D&D Superboss pipes, loud enough but not too loud nice performance upgrade, check their site.
Old 04-19-2009, 06:42 AM
Raventhik's Avatar
Raventhik
Raventhik is offline
+1...
Old 04-19-2009, 06:46 AM
user 82020's Avatar
user 82020
user 82020 is offline
I have samson ovals, not to loud but a nice low rumble!
Old 04-19-2009, 07:05 AM
DaltonHD's Avatar
DaltonHD
DaltonHD is offline
I have the SE on my 04 RC..Nice sound for us full-circle guys.
I would be all-over that SE deal for $75!
Quick Reply: My pipes are too loud. Recommend something else.
