My pipes are too loud. Recommend something else.
Old 04-18-2009, 07:37 AM
xxxflhrci's Avatar
xxxflhrci
xxxflhrci is offline
Before you go spending a lot of jack on a new set of mufflers, you might try putting a lollipop baffle in front of your mufflers. I rode my bike 53k miles with Samsons and the stock headpipes. At 53k, I put on V&H Duals with the same mufflers. The bike was louder. I added the baffles as a tuning aid, but also noticed that it quitened the exhaust a good bit, especially at interstate speeds.
Attached Thumbnails My pipes are too loud. Recommend something else.-imag0060.jpg   My pipes are too loud. Recommend something else.-lollipop-2.jpg
Old 04-18-2009, 07:45 AM
stafford's Avatar
stafford
stafford is offline
You can buy some Rush mufflers and work with different baffles. They have a nice deep sound regardless of which size of baffle you use. I'd be willing to bet that you'd be very happy with the 1 3/4" baffles. It makes a difference what size your engine is too. I've got the 2 1/2" baffles on an 88 and it's loud but doesn't have that sharp crack like they do on a 96" engine. My friend put a set of Rush slip ons with 2" baffles on his 96" and it's got a low kind of a hushed sound, He loves it and it does sound good. Rush makes a good qauality product and if you shop around you can find decent pricing on them.
Old 04-18-2009, 07:54 AM
RODEO's Avatar
RODEO
RODEO is offline
Not to hijack but - Those "lolipop" baffles bring back memories! I had a set of those on my first bike, a Honda 305 Scrambler. The pipes ran up the side of the bike and the mufflers were removed but those baffles were installed. It worked like a charm and you could go from open pipes to quiet pipes quickly. Those baffles were more like washers inside with a hole in the middle though. Mine was a "hand me down" from my older brother and was a really nice turquoise blue color.
Old 04-18-2009, 07:57 AM
Dirt-Kid's Avatar
Dirt-Kid
Dirt-Kid is offline
I wonder if the Vance and Hines ovals would have been ok for you if you did not have the true duals? I'm still in decision on what slip-on to buy for my bike,won't be using true duals my self cuz I prefer the 09 head set-up.
Old 04-18-2009, 08:05 AM
rg_dave's Avatar
rg_dave
rg_dave is offline
Man did you ever bring back memories! I had one of those!
Old 04-18-2009, 08:17 AM
wjl24's Avatar
wjl24
wjl24 is offline
Does muffler packing material make any difference?
Old 04-18-2009, 08:19 AM
Anthony8858's Avatar
Anthony8858
Anthony8858 is offline
I put the TD on the same time as the Ovals, so I couldn't tell you. But I would have to guess that the True Duals are making the Ovals even louder.
Old 04-18-2009, 08:35 AM
OldArmy's Avatar
OldArmy
OldArmy is offline
That solution looks very interesting. Can you give a bit more information? I dearly love my Rineharts for the middle-aged crazy stuff but it does get old on the highway. Additionally I have a need to be quieter, especially when cranking up and riding out in the early morning. Seems they are something that could be cranked both ways depending on need?
Old 04-18-2009, 09:29 AM
xxxflhrci's Avatar
xxxflhrci
OldArmy,
They really simple....Just 1" washers welded on a 1/4" bolt stem. You could use larger washers for more "baffle" if you wanted to. I cut a slot in the bottom of the stem so I could tell which way they were turned in the pipe and turn them with a screwdriver to adjust them.
Old 04-18-2009, 09:53 AM
uweldit's Avatar
uweldit
uweldit is offline
Try the SE slipons, 64985-07A.
Quick Reply: My pipes are too loud. Recommend something else.
