T-Rex duals and billet ext brake lever..
Is anyone else running the Hard Krome T-Rex pipes with the HD billet extended rear brake lever? I just installed my lever and had to modify it due to the larger diameter of the pipes. What should have taken me 20 minutes to install ended up being 1 1/2 hours. [:@]
Thanks for the input. I went with the HD setup due to having them on my Night Train. I needed to do some grinding on the corner edge of the bracket for clearance. Finished it off with a coat of clear to prevent rust. It's not seen as it is on the backside against the pipe. It was just frustrating.
Biker Bob
06-30-2008 12:27 PM
