PCV Void Harley Manufacturers Warranty??
#31
Second, You cant just take off a trike kit and the reverse gear.
![Roll Eyes (Sarcastic)](https://www.hdforums.com/forum/images/smilies/rolleyes.gif)
My warranty issue had nothing to do with the kit or the reverse gear. But because I had modifed the bike Myrtle Beach HD told Harley corprate about my bike, the VIN # was entered into the main data base to void me from any warranty claims, except for Government recalls to be repaired under warranty
I will say that if I would have known that the dealer here in Myrtle Beach was going to screw me over ( BTW they knew me and my situation with having a prosthetic leg ) I would have taken it up to Maryland to have it repaired were I bought the bike new. They would have fixed it without any problem for me.
What your selling dealer will do for you and what another dealer will do for you is were that problem lies with the Warranty and extended warranty
Also if you decide to cancel your extended warranty, They will charge you a $100 administration fee to send your money back to you via the dealer who sold it to you
#32
Unfortunately the "Magnuson-Moss Warranty Act" will not completely protect you from a voided warranty by adding the PCV.
It is not a non-OEM replacement but an addition that modifies the manufacturers specifications as to fuel/air mixture etc.
The "Magnuson-Moss Warranty Act" was for people that went to their local auto parts store and purchased non-OEM brake pads and such. These were direct replacements for the OEM parts.
The PCV modifies the manufacturers specifications and any damage reulting from the operation out of the manufacturers specs can void the warranty if they can prove that the part caused the problem.
For instance; if you install the PCV and the map sets the air/fuel mixture too lean or too rich and that causes the problem, it would not be covered under warranty.
To the OP, their suggestion that the PCV will mark its presence even if removed is untrue unless a fault code is generated. It works downstream of the ECM which has otherwise no awareness of its presence. If a code is thrown and not cleared it would be readable by the dealer or anyone else. In 2½ years of running a PCIII and now a PCV-AT I've never had a fault code show up on this bike, and there have been only a few reported here, mostly or entirely from improper installations like failure to install O2 sensors, etc.
#33
Ftanner,
Touting the MM act ain't going to get the problems fixed if u modify the bike. Don't think that it's easy to fight the MoCo on warranty items, cuz it's not. They have the Engineering Staff that can make anything appear to be your fault.
No flame intended, but MM is not the do-all some may feel it is.
Misrepresenting what you have done to your bike at the dealership for repair is Fraud.
M&M Act was designed for automotive non-OEM replacement parts like brake shoes, wipers, alternators etc.
aftermarket, closed, davidson, exhaust, harley, harleys, issues, manufacturers, modifications, pcv, post, prove, rich, void, warranty
