Clutch adjustment question
Just adjusted my clutch per the service manual. Loosened the cable, turned the clutch adjustment screw till seated lightly and backed out 3/4 turn. Tightened jam nut.
Here is my question. Seems like the clutch now engages much later in my release than previously. In other words, the friction began 1/2" away from the grip before, now friction begins 3/4" away from the grip.
Did I do something backwards?
In the clutch forum it describes a much easier clutch adjustment method that works every time for, the first time. Loosen the clutch cable all the way. Hold clutch lever to handlebar and turn in adjustment screw until you feel the lever start to come up off the bar. Back it off a bit and do it again. Do this a few times to zero it in, than back off the adjust screw 1/2 turn and tighten everything down, and adjust cable. It should be dead on. And with a properly adjusted clutch you should feel it start to engage or drag at approximatley 1/2 to 1 inch from the bar as you release. I like it at 1/2 inch, gives me more control for feathering or slipping the clutch in tight turns.
lp
But I will be the first one to say I am not an experianced gear-head. I just followed the directions I found in the clutch forum from a tech. Ofcoarse any adjusting to your clutch to make it tight you do at your own risk.
