Stebel Nautilus Airhorn Compressor
Old 04-14-2009, 08:18 PM
Dan 55's Avatar
Dan 55
Dan 55 is offline
4th Gear
Default Stebel Nautilus Airhorn Compressor
I've been following the airhorn threads and many say to locate the compressor in the space in front of the battery once it's separated from the Stebel horns. All the photos show the compressor lying on its side in that location. However, the instructions that came with the Stebel horns say the compressor should ideally be mounted vertically or no more than 15 degrees from vertical. Is there any reason why the compressor has to be mounted vertically? For you guys who have mounted the compressor horizontally, any problems? Thanks. Oh, by the way, this Stebel Nautilus is deafening.
Old 04-14-2009, 08:44 PM
deni's Avatar
deni
deni is offline
I've mounted three like the instructions say. It is challenging.
Old 04-14-2009, 08:52 PM
deni's Avatar
deni
deni is offline
BTW, I think the compressor has oil in it.
Old 04-14-2009, 09:01 PM
mymatrix's Avatar
mymatrix
mymatrix is offline
I bought a billet clamp from http://baggermansshop.com/baggermansshop.aspx
I have the compressor clamped to the front left downtube.
Old 04-14-2009, 09:17 PM
Arvid's Avatar
Arvid
Arvid is offline
Default Stebel relay?
Dan, did you have to get a seperate relay? I am planning on ordering a Stebel tomorrow. I saw on a previous Stebel thread that someone recommended an "eastern beaver" relay kit.
Arvid
Old 04-14-2009, 09:22 PM
deni's Avatar
deni
deni is offline
Go down to the local auto parts store & get a standard relay. $5-$7 tops
[IMG][/IMG]
Old 04-14-2009, 11:30 PM
mgrimmace's Avatar
mgrimmace
mgrimmace is offline
6th Gear
dan i cut my stebel plastic horn and trimmed to fit in the stock horn cover its tight but it does fit.i mounted the compressor beside the fuse block and used zip ties,ran the air line through the frame to the horn.i also mounted the relay beside the compressor. you cant tell the horn from stock till you hit the button...LOUD
Old 04-15-2009, 12:11 AM
phat96's Avatar
phat96
phat96 is offline
Good job, Dan and Grimmace, you should have a lot of guys following this thread. That is a loud horn.
Old 04-15-2009, 04:52 PM
2d3k2h's Avatar
2d3k2h
2d3k2h is offline
Thumbs up
Been running one for 2 years .Have the compressor in the hole in front of battry box.IT lays at an angle....no problems yet..run air line under tank and out by stock location,Have mine in HD air-wing cover.....06 Street Glide.
Old 04-15-2009, 08:32 PM
Dan 55's Avatar
Dan 55
Dan 55 is offline
4th Gear
Arvid: I got mine from Aerostich and it came with the relay. I also bought the wiring kit from them which had and inline 20A fuse and assorted wire and connectors. Made it very easy. Total with shipping was $57.
Quick Reply: Stebel Nautilus Airhorn Compressor
