Stebel Nautilus Airhorn Compressor
Stebel behind saddle bag
I've tried to find an earlier thread where the poster mounted his Stebel behind the saddlebag. I don't have room to do that on my 1990 bike (these things seem bigger in the hand than on the shelf!), but that is another possible option. I still haven't found a way to mount mine!
I did that and it has worked great, nice and loud. You may be able to fit one on each side if you want.
https://www.hdforums.com/forum/attac...0405091746.jpg
Thanks for posting that, it was that very post I had in mind when I wrote! I think later bikes than mine must mount the saddlebags further away from the bike, as my Stebel won't go where you mounted yours.
Stebel Nautilus
I mounted mine on the engine guard, of my FLTR, left the OEM horn in place, and ran "jumper cables" to the attached compressor.
I bought my horn at the local auto-zone, and there was a relay, included in the package
(hopefully this link will work) (cool it DID!!)
Note the wrapped electric tape just above and to the right. I wrapped the relay to insure weather tight. and mounted the relay onto the frame
Note the wrapped electric tape just above and to the right. I wrapped the relay to insure weather tight. and mounted the relay onto the frame.
I mounted my compressor under the battery tray so it sits horizontal and ran a air line up to the cut off horn section that I mounted in the stock cow bell. I would have liked to have mounted it as instructions said, but I could not find a hidded way to do that. I thought the worst case was that it would not last and I tossed $40 out the door, buttwo years later and it still works . I like that you can not tell it's there until I push the horn button.
Just finished installing a new Stebel Nautilus air horn on my '06 RKC. Thanks to this thread, I was able to keep everything looking stock.
Once I separated the horn and compressor, I removed the old horn from the cowbell.
I placed the compressor behind the right side cover and ran a length of hose with wiring loom for protection to the horn that I installed inside the cowbell.
After wiring everything up with the relay that came with the horn, I installed a fuse as per directions.
Works great, and nearly invisible inside my stock horn cowbell. And yes, I think it might wake the dead!
