Trailer hitch for 09 Ultra????
Old 04-13-2009, 09:03 PM
09 UltraFine's Avatar
09 UltraFine
09 UltraFine is offline
Default Trailer hitch for 09 Ultra????
I am looking at installing a trailer hitch on my 09 Ultra, I want the reciever type. Anyone have any suggestions on which one to buy? Thanks for info
Old 04-13-2009, 09:20 PM
firefighter156's Avatar
firefighter156
firefighter156 is offline
Thumbs up Ultra Hitch
Hitch made by Bushtec. They are not cheap but in my opinion they are the best. Receiver slides up into fender. Solid mount. I have provided the link. Check it out.
http://www.bushtec.com/hitch.html
Old 04-13-2009, 09:40 PM
TheShrink's Avatar
TheShrink
TheShrink is offline
Here's what you want: http://mchitch.com/
They are great people to deal with and make a great hitch. They now also offer color matched hitches.
Old 04-13-2009, 09:42 PM
cap5369's Avatar
cap5369
cap5369 is offline
Hitchdoc has them now. I just put mine on about 2 weeks ago. The nice thing about it is that is is all crome and you can not even tell it is there once you remove the reciever.
Old 04-13-2009, 10:04 PM
bksmoky's Avatar
bksmoky
bksmoky is offline
cap5369---what did you use for a wiring harness and plug in? Is the plug out of sight when not using the hitch?
Old 04-13-2009, 10:24 PM
cap5369's Avatar
cap5369
cap5369 is offline
bksmoky – When I bought the Starlight trailer they gave me the wire harness. I used the plug and play adaptor on the lights then spliced from the adaptor to the wire harness. When I take the receiver off I use a tie wrap and tuck it up under the fender. There is a flat bar under the fender I coil it up and tie wrap it under the fender out of site. I also use black electrical tape and tape the end so no dirt gets inside the plug.
Old 04-13-2009, 10:26 PM
themooser98's Avatar
themooser98
themooser98 is offline
I put a Bushtec on mine. When not used it can be removed simply by removing a pin leaving only the hardware on the bike which you wouldn't even know you have the bike setup for a trailer hitch.
Old 04-14-2009, 07:34 AM
Firebike32's Avatar
Firebike32
Firebike32 is offline
Love my Hitch Doc. Good people to work with.
Old 04-14-2009, 09:04 AM
1HD2NV's Avatar
1HD2NV
1HD2NV is offline
Hitchdoc for hitch, this http://www.alfa-mate.com/ for wiring.
Old 04-14-2009, 10:33 AM
cap5369's Avatar
cap5369
cap5369 is offline
I bought my plug and play from MCHitch. You will have an adaptor that comes off of the plug and play with your wires that you will use to tape into the wire harness going to the trailer. This is the one that I used.
http://www.mchitch.com/Wiring_Harness_Instructions.htm
Quick Reply: Trailer hitch for 09 Ultra????
