CD player skips when riding
I really enjoyed my CD player on my Ultra last year. This year it is skipping a lot when I'm riding. When the bike is setting still, there is no problem. What could it be?
I have an extended warranty so I guess they will have to fix it.
+14.7 on the cleaning disc. Geez, these things sit out in a garage for months on end while one of the most precision optical devices you'll ever come across in everyday life gets foggy & clear, foggy & clear, over and over.
One of the cleaning discs with the felt (some have a little "brush" thing, which works reasonably well also) will probably take care of it.
One thing to figure -- Does it skip with both MP3 and standard CD's...? There's an error-correction algorithm (CIRC-Logic) for CD playback that MP3 (data) doesn't have. If a normal disc plays well, but a disc of MP3 data doesn't, it's a pretty good indicator of dirty optics.
You probably dont want to use a cleaning disc. I worked as a tech for Harman sine 1988...spent the last 4 years running the Harley Warranty analysis and refurb team. I cant tell you how many cleaning discs we received jammed in units, and it's not exclusive to the Harley unit. Most of those brush style discs have a warning on the jewel case warning you that they should only be used in tray style CD players. Just about every motorcycle and car head unit uses roller type feed / eject mechanisms. If the brush hits the roller at the wrong angle, it will jam the unit.
Beyond that, most skipping issues on the HK unit is actually related to the SDRAM circuit. There are occasions when the SDRAM...where 40 second skip protection is stored...needs to be reworked. This is for both audio and MP3 discs
JohnScrip is correct in his pointing out the harsh environment that these units are subjected to and the fact that the lens could very well be dirty. If you have a warranty, by all means submit the unit. If anyone has one out of warranty, check out Iron Cross Audio (www.ironcrossaudio.com)
CD
I had almost the same problem. Mine was that my radio/cd would reset while riding. It would go completely off and then restart. turned out that i did not completely retighten the battery terminals when I had loosened them for some earlier projevt. Check the terminals -- could be the reason.
h
h
