Tour pack turn signals?
Old 04-13-2009 | 11:22 AM
slime_dog's Avatar
slime_dog
Default Tour pack turn signals?
Anybody here running the Ride Time turn signal conversion for the Ultra Tour Pack? Was it an easy conversion?
Old 04-13-2009 | 11:47 AM
hdbe's Avatar
hdbe
have not heard of it..got a link?
Old 04-13-2009 | 11:56 AM
slime_dog's Avatar
slime_dog
This has been discussed several times already. I should have searched before posting. I will retract the question.
Old 04-13-2009 | 12:11 PM
TheShrink's Avatar
TheShrink
I'll comment anyway ...
I am running both, the side LED's and Rear LED's from RideTimeTechnology.com. Keith is a real nice guy and his products are top notch. I am running all of it through my Badlands Illuminator.
Old 04-13-2009 | 12:52 PM
slime_dog's Avatar
slime_dog
Thanks Shrink...
Old 04-13-2009 | 06:10 PM
BillyG0856's Avatar
BillyG0856
I now have running, stop, and turn on my tour pak. Fairly easy to do if you have the 'HD turn signal converter'....part # 69461-06A.
Once this converter is installed, locate the 'purple' wire for the left, 'brown' wire for the right, and solder 2 wires into the loom. I then ran the 2 wires into and thru the Tour Pak harness to the trunk. Inside the trunk, locate the brake light wires (red for left, red/white for right), clip and solder the new wires....and you'll have both brake light and turn signals.
I left a small 'loop' at the tour pak harness to install a 'quick disconnect' plug @ a later date.
Billy G
Old 04-13-2009 | 07:49 PM
Mick's Avatar
Mick
Well it's sort of easy......kinda.....
I just installed the FlashR setup on my 09 Ultra and it works really slick.
http://www.ridetimetechnology.com/flashr.htm
I even ran a purple wire and a brown wire for the signals.
This makes it a bit easier.
http://www.ridetimetechnology.com/qc...er_adapter.htm
The neat thing about this , is that the color codes are proper and labeled clearly , which makes the FlashR setup pretty easy.
There is a conduit from the tourpack left front corner , which the wires run to the main harness.
I pulled the 2 new wires through this conduit , slitted the conduit near the battery , and over to the qc adapter.
This way none of the bikes wiring has been altered and all items are plug in to connect or disconnect.
I also installed the badlands illuminator , which also plugs in to go with the Glide Lights.
http://www.ridetimetechnology.com/glide_lights.htm
I've had some great input (from behind) and this setup looks and works really slick.
Very satisfied with the RideTime products.
Mick
Old 04-13-2009 | 07:56 PM
mymatrix's Avatar
mymatrix
http://ridetimetechnology.com
Old 04-14-2009 | 06:11 AM
The Old Man's Avatar
The Old Man
I just did their tombstone tailight set up. 100 LED's and worth it. Almost everything they make is an easy install and all of it high quality!!!
Old 04-14-2009 | 07:34 AM
slime_dog's Avatar
slime_dog
It looks like ridetime has removed the tour pack turn signal conversion? What's up with that? They used to sell a conversion kit.
Quick Reply: Tour pack turn signals?
