PCM V to SERT???
If you have a competent dyno tuner, a SERT / TTS / SEST / DirectLink, will ALWAYS make for a better "riding" bike than what you can get with a PC.
Anyone who disagrees, simply has NEVER had a properly tuned bike.
Sure a PC will make a bike run better than stock. If 80'ish % is "good enough", then perhaps a PC also good enough. There is no such thing a MAP that is "right" for bike other than the one it was (supposedly) created on, via dyno tune. They may be "in the ballpark", but no "homerun".... no way.
One other tidbit.... "Proper" tunes rarely come from dealerships ~ partially due to training, but more to do with volume of tunes and dealership mentality.
Your right there Phil. I see your point. I did get a great tune and I am very happy with the SERT, I did get it at the dealer and I trust only one to do a tune the rest not so . A good tunner is hard to find.
Tom
something else to remember: almost no PC maps will have any modifications at 0% throttle position, so if your bike is running ****ty in that range, decel pops, etc. it is most likely a shortcoming in your factory ECM's fuel map, as the canned PC maps arent making any changes in that range.
phat_ridegt
04-05-2012 04:24 PM
jrudicel
05-27-2007 05:38 PM
