Anyone have these LED Turn Signal Kits
Been thinking of switching over my bullet style turn signals to led. I came across these two different kits from Badlands and Custom Dynamics. Looking at installing a Run Turn Brake also with the built in equalizer. Any comments or suggestions. Are they going to be that much brighter over a bulb ? One advantage I see not having a front light bar would be the front signals would be running at 100% brightness instead of 30% with the incandescent during run mode.
"Most front motorcycle turn signals are dual intensity, they light up as a low intensity running light at approximately 30% of full brightness and when the turn signal is activated they flash from the running light intensity level (30%) to full brightness (100%).
Eclipze™ LEDs and the Radiantz Drugz are designed to increase your frontal visibility First, the running light intensity is changed from 30% of full brightness to 100% of full brightness making you motorcycle more visible all at times. Secondly, when a turn signal is activated the LEDs flash from 100% to 0% brightness giving more contrast as a turn signal, thus increasing your visibility when you are turning. "
Lights
http://www.badlandsmotorcycleproduct...rn-Signals.htm
Another brand
http://www.customdynamics.com/harley...gnal_retro.htm
Any +/- with either one of these Run Turn Brake modulator
Alarm compatible, Led compatible, No heat, No load, Built in load equalizer
Badlands Illuminator Pro or Street Magic
Street Magic will blink. Badlands does not.
http://www.customdynamics.com/tailconversion_kit.htm
Sorry for the long post. I thought others would find this interesting also.
Lights
Another brand
I have the complete Kuryakyan Panacea System. It was all plug and play, very easy to install. I dug up some of the old info that I still have links for, so maybe this will help you
Bob
https://www.hdforums.com/forum/touri...il-lights.html
http://www.cyclespot.com/panacea.html
Bob
I have the custom dynamics led turn signals in the rear only. They are the dogeyes, turn signal/brake light kit. They are very bright and effective, other riders question if I am riding with my brake light on. I had 4 other riders purchase them for their bikes. And the price is right too.
Badlands Illuminator is the best run/turn/brake controller on the market. The others will over heat on you eventually and the Illuminator has a built in load equalizer.
Drugz L.E.D.'s are made by Radiantz, also the best company for L.E.D.'s.
I am running the Badlands Illuminator and alot of Radiantz L.E.D.'s and couldn't be happier.
I have the CD LEDs on all four corners! The rear is managed by the BADLANDS illuminator/Load Equalizer and I could not ask for a better system! All plug and play and bright as I wanted them! Too add to the mix I also installed the BrightAssLight (BAL1) as My rear tail light...I'm very happy with the light My bike puts out in the day as well as the eve!
Good Luck on your choices! Mike
