Drive Belt Dust Question
Old 04-11-2009 | 05:59 PM
Tanker2's Avatar
Tanker2
Question Drive Belt Dust Question
I have a 99 Ultra Classic with 28000 miles. Someone before I owned it, had changed a rear tire a got the flap on the belt guard on top of the belt and wore one side of the belt. So this winter I replaced the belt with a new Harley belt. The newer belts are made of a different material then the old one was. A lot harder material. I used the same sprockets . They showed a little wear but not worn out. Belt alignment is good and it tracks to the outside when it rolled forward and the inside of the front belt drive sprocket when rolled backwards just like the manual says it should. Belt tension is correct. My question is when I ride I get belt dust or particals that sick to the inside of my exhaust. Is this normal with these new belts. Does it stop after they wear in? The new belts are made of a Kevlor or something like that. The older one was more of a hard rubber. Has anyone had any experience with this?
Old 04-11-2009 | 06:02 PM
txfxstrider's Avatar
txfxstrider
When did they change belts? I have not noticed this on my 07 or 96.
Old 04-12-2009 | 01:39 AM
Arizona's Avatar
Arizona
Wow never noticed it myself on my '05 or the new bike. But then again I live in a dusty area so maybe I wouldn't be able to see it even if it was there.
Old 04-12-2009 | 06:49 AM
hdbe's Avatar
hdbe
cant go back to 99..but i can tell you i've always gotten belt dust from my 06 deluxe
Bill Murray
05-02-2013 12:22 AM
mikeallenbrown
08-23-2011 09:15 PM
HarleyGirl76
VRSC Models
02-12-2008 07:24 PM
GlennsGlide
08-09-2007 10:55 AM
clayman
10-15-2006 03:08 PM
Quick Reply: Drive Belt Dust Question
