Rear pulley questions
I would like to go this route also since my adjusters look like their 3/4 way back. The 09's have a 68 vs 66 tooth rear pulley on 07's. Doesn't seem like that would be that much larger in diamenter but not many in stock to measure. Sporster pulleys are 68 tooth also but don't know about the belt.
rmc115 has a friend that is trying it out as we speak so hopefully he will have an answer soon.
I just looking for a cheaper way, using my belt and not eliminating the compensator or changing trans pulley.
The least expensive way I've found without eliminating the compensator is the Evolution Industries 49 tooth clutch gear. Way less labor and should get you where you want to be.
I did the 30 tooth change over, worked for me. No changes in speedo accuracy either.
Forum build pics:
https://www.hdforums.com/forum/touri...re-useful.html
Evo website:
http://evoindusa.uia.net/product_inf...6e0fda5889f418
Forum build pics:
Evo website:
deadhawg
08-20-2023 07:07 PM
00wildcat
08-10-2011 02:10 PM
