07' Street Glide winter build
Got my Glide back a couple weeks ago, and I'm liken' it alot.
All work was done at Lawrences Cycles in Coeur d' Alene, Idaho. Jugs punched out to 103", head work done by Lucky Lawrence, bigger valves, ported and polished, S&S 570 gear drive cams (crank run out was only .0017") SE 50mm throttle body, SE adjustable push rods, SE lifters, squish set at .030", Rinehardt true duals, Forcewinder intake, SERT (tuned by Jeff)
This thing runs BITCHIN'! Had it up to 105mph in 4th gear and it was still pullin'
Smile and pucker factor are way the hell up there!
