need help
What level was the fuel when this occurred? That's another way to tell. If you fill up and runs fine it could be covering the holes. Could also be bad gas or a broken or breaking injector wire. I'd fill the tank and try to see how that works then it might narrow it down to that.
For a broken injector wire, the little pigtail that goes out from the top of the frame rail where they are secured to the injectors themselves, the leads can wiggle themselves until they partially break. Here's what the holes in fuel hose look like from rubbing.
well managed to change the fuel filter ok. really needed it. but no holes in hoses and bike does not run better. spits,stumbles, coughs, surges, loss of power , doggy. hard to start takes 3 or 4 attempts.fuel is good. dealer says 80 bucks to diag. guess ive got little choice
is there a way to check fuel pressure???? im convinced this is fuel related
