Bike finally back...here are my tensioners
Old 04-09-2009, 02:02 PM
HDRider2002's Avatar
HDRider2002
HDRider2002 is offline
Default Bike finally back...here are my tensioners
Just got my scoot back from having the SE Hydraulic Tensioner kit installed, along with the HQ-0034 cam. here is what the tensioners look like at 30K miles.
Old 04-09-2009, 02:10 PM
Scorpion07's Avatar
Scorpion07
Scorpion07 is offline
DAY-UM! Springs look good though!
jerseyjeff62's Avatar
jerseyjeff62
jerseyjeff62 is offline
30K running what kind of oil?
Old 04-09-2009, 02:14 PM
RoadKingRon1's Avatar
RoadKingRon1
RoadKingRon1 is offline
Um yeah, what oil and what was your change interval?
Mine at 18K were bad but not that bad. We had to drop the oil pan and remove the oil pump to get all the fragments out of mine...
How do you like the hyd. tensioner? I went back gear drive.
Old 04-09-2009, 02:18 PM
HDRider2002
30K miles and running basically DINO oil. I'm most likely going to be switching to synthetic. As far as interval goes every 3000 miles, plus the end of the season. I will say the riding i do is generally 'aggressive', but who knows if that really even plays a roll. Mainly just enjoy the peace of mind to know its not an issue at this point. As far as the hyd. tensioner...i guess i really don't have an opinion...still trying to get used to the new cam more than anything.
Old 04-09-2009, 02:21 PM
liltrk's Avatar
liltrk
liltrk is offline
Looks like you got 'em before too many bits got shredded off.
Old 04-09-2009, 02:41 PM
jerseyjeff62
if something works why change? do you just want to change now that the rings are seated?
Old 04-09-2009, 02:47 PM
HDRider2002
Ha, yeah, i just wanted to ease into the first 30K Mainly going to change due to some recommendations from guys that have been running it, decided it can't hurt
Old 04-09-2009, 03:30 PM
simpkinst's Avatar
simpkinst
simpkinst is offline
I was thinking of having the same thing done to my 06 FLHX HQ-0034 and tensioners. Who did the work and, if you don't mind sharing, what did it set you back?
Old 04-09-2009, 03:41 PM
HDRider2002
I had a friend of mine do the work for me, i want to say it was just shy of $1000 for the SE Hydraulic tensioner kit, cams, adj. pushrods, Black OPS lifters, and Timken Inner bearings. The labor was a couple hundred bucks, though the dealer quoted me 5-6 hours for the labor. Just the cams was going to be 4 hours, so apparently they add at least an hour labor for the tensioner upgrade?
Quick Reply: Bike finally back...here are my tensioners
